Author Topic: Bullfrog A7 Vs Hot Spring Vanguard  (Read 7660 times)
cchaynes
« on: July 22, 2019, 02:55:36 pm »
The local area is Philadelphia but will buy out of state, likely DE or NJ.
So far the quote on the Vanguard is higher by a couple of thousand dollars.
I like the Hot Spring but have read some pretty unflattering reviews of them having a lot of part failures.  One pro to the HS is the salt system.
Any thoughts would be appreciated.
castletonia
Re: Bullfrog A7 Vs Hot Spring Vanguard
« Reply #1 on: July 22, 2019, 03:15:47 pm »
Really curious what the product failures are.  As a Hot Spring/Caldera/Marquis dealer I may be biased, but I have few failures on Highlife Hot Spring.  General statement here, both are quality brands.  I don't know Bullfrog pricing, but unless someone in the know can comment, I wouldn't expect there to be a couple thousand dollar difference.  If these are the same dealer, it sounds like they are trying to emphasize Hot Spring as a more premium product and if different dealers, maybe one is giving you their bottom price up front and the other has left room for negotiation.  Either way, the price difference in my opinion is irrelevant unless the Bullfrog is the better hot tub for you.
« Reply #2 on: July 22, 2019, 03:24:42 pm »
what prices are you being quoted and what is included in the price.  Extras and add-ons can affect the price by thousands of dollars.
cchaynes
« Reply #3 on: July 22, 2019, 06:22:51 pm »
Different dealers, but i think thew dealer for HS is on the high side?
Total price delivered is 13,799
The price on all will include cover, cover lifter, matching upgraded stairs, electric subpanel, chemicals and delivery.  Salt water is usually $349 for the start up that lasts 4 months and I will include the salt water for free!!  I can do that with any deal.
Not sure what the sub-panel saves me?
The BF dealer is quoting a price of 11,300 (need to verify delivery but that is with wellness pump and ozone (which i like less than salt)
Over 2k delta seems high, what is a fair price on this vanguard?
BTW, it as from a consumer reports style site, lots of failed heater and pumps and other gripes.  That said, people eon here seem very happy with HS quality
Craig
castletonia
« Reply #4 on: July 22, 2019, 07:53:10 pm »
That price is pretty fair on the Vanguard with Salt.  The Bullfrog price seems low but I could be wrong.  When considering the price, keep in mind the options can swing the price a lot.  With Hot Spring, Freshwater Salt is $399, the GFCI sub-panel is $399 and depending on which lift and steps, that could be another $500-$800.  Same can be said with Bullfrog (which lift and step)?
Again, I will not tell you what to do.  I would wet test and see which you like better.  The $2500 is irrelevant unless the hot tub works for you.  Also research each dealer as they are the ones supporting you after the sale.
While I haven't been on Consumer Reports, that statement is surprising to me.  In my area there has been Hot Spring representation for 35+ years.  The company I work for has been with Hot Spring for the last 2.5 years and Caldera 5 years.  I order all parts and process all warranty claims.  The amount of jet pumps I have ordered is in the single digits and heaters are similar.  These numbers are for what we have sold and all other operational Hot Springs in our territory.
I think anyone in this industry would agree that all hot tubs will break if you own it long enough and that no company makes an indestructible product.  That being said, I'll take my chances with Hot Spring/Caldera any day because I know the manufacturer is going to support me as a dealer and that means my customer will be taken care of.  Having been in the industry 18+ years and having dealt with many manufacturers, I have never had this amount of confidence from anyone else.  There are a few Bullfrog guys here that can speak about them as a company so I won't because I have no direct experience.
cchaynes
« Reply #5 on: July 22, 2019, 07:58:28 pm »
Does the lineup even have an MSRP?  I don't like how murky the pricing is in the industry.
here is a link to the reviews I mentioned.  In fairness its like mostly pissed off people but lots of early breakdowns referenced.
https://www.consumeraffairs.com/homeowners/hot-spring-spas.html
« Reply #6 on: July 22, 2019, 08:12:08 pm »
Couple points here. Consumer affairs is a pay to play review site. You will notice a few brands with hundreds of reviews and the rest have under a 100. I just looked and think I saw 67 reviews. I didn’t read them but I’m guessing they aren’t all bad. Even if they are Hot Springs makes like 20,000 or so Tubs a year. In my mind that’s a pretty good ratio of complaints to number of tubs sold
« Reply #7 on: July 23, 2019, 12:34:51 am »
 Both are nice, so you can't go wrong.  Have you wet tested yet?   If not, it could make a difference in your decision.   The price on the Bullfrog is low, were at 13,500 with the options quoted.  Don't buy into the salt vs ozone crap.  Ozone has been around a really long time.  And when used right with a mineral cartridge and a product like replenish, it's hard to beat.  I honestly thing there are more cons then pro's to salt systems, but it's you money and pcs of mind.
    Wet test and then decide, comfort is key, the rest is politics..
Qrose
« Reply #8 on: July 23, 2019, 09:00:20 am »
I have had my Aria for almost a month now. The Aria is the same size as the Vanguard. In my opinion it is a step above the Bullfrog. The quality of the tub is outstanding. I’ve had ozone and now have salt. I would never go back. The salt is amazing. If you don’t have sensitive skin it might not be an issue but I do and I  can’t speak highly enough about it.
cchaynes
« Reply #9 on: July 23, 2019, 11:04:46 am »
Thanks everyone!
We have also received a better quote on the Vanguard of 12,400 all in.
One quick question, is the sub-panel for the hotspring proprietary?  Is that why they include it?
Cheers
« Reply #10 on: July 23, 2019, 02:22:13 pm »
Thanks everyone!
Cheers
I'm not sure I'd call it proprietary as much as it is "different" and not at Home Depot. That's why its included so the electrician or do-it-yourselfer won't scratch their heads figuring out what is needed.
cchaynes
« Reply #11 on: July 23, 2019, 02:28:32 pm »
 :)Thanks!
castletonia
« Reply #12 on: July 23, 2019, 06:40:37 pm »
Thanks everyone!
Cheers
Thats a good for you price on the Vanguard.
« Reply #13 on: July 24, 2019, 12:17:49 am »
 It's never really "included"  You are paying for it somewhere.   That said, glad the came down. It's a good price.
cchaynes
« Reply #14 on: July 24, 2019, 09:48:50 am »
We are definitely leaning that way.  We like the look of it better and want the salt.
