Author Topic: Beachcomber 300 series leak  (Read 2281 times)
muso31
« on: July 18, 2019, 04:57:32 am »
Hi all! I've noticed a leak around the O3 injector pipe in my beachcomber 321. It's a 2009. Does anybody have any ideas? It's wet above the pipe also so I assume this is coming from higher up and trickling down. It seems like a serious problem but any help would be greatly appreciated
Photo - https://photos.app.goo.gl/aovGDLu9cgb1eM4j6
..edit looking into this it appears the Jet nearest the O3 injector pipe is leaking, the O rings are very old so I may replace them
« Last Edit: July 18, 2019, 10:47:15 am by muso31 »
bud16415
Re: Beachcomber 300 series leak
« Reply #1 on: July 18, 2019, 11:44:53 am »
No expert here, but it looks like the seal between the jet and the tub. Not sure what the fix is or if there is a patching method that works.
« Reply #2 on: July 19, 2019, 08:17:18 am »
Cutting out all the foam, disassemble the jet, clean the mating surfaces and replace the o-ring.
