Author Topic: OPTIMA 880 CONTROL PA HELP  (Read 1883 times)
AMMOT23
« on: January 16, 2019, 10:59:24 am »
quick question,my control pad on my sundance optima is lit ,but no readout,i do only get the heat icon and the change filter icon,there is also no function from any of the buttons,the tub is still heating,any simple trouble shooting suggestions i believe it is a 2007 optima sundance thanks in advance
Re: OPTIMA 880 CONTROL PA HELP
« Reply #1 on: January 17, 2019, 10:47:55 pm »
Sounds like a bad topside but you could always follow the cable underneath, unplug it and reset the spa.  Doubt that will work but I have seen it work in the past.  They can work loose over time if they weren't fully plugged in to begin with.
AMMOT23
« Reply #2 on: January 18, 2019, 12:25:51 pm »
thanks so much,i did unplug it but I did not reset while it was unplugged, I will try that,if you were a gambling man would you think pad or board is bad,thanks in advance
« Reply #3 on: January 18, 2019, 09:11:38 pm »
 90% sure it's a bad top side.
