Author Topic: Check Valve  (Read 2133 times)
Bonfire
Check Valve
« on: January 12, 2019, 03:27:55 pm »
Hot Springs limelight Pulse model, no ozonator. I had to order a new 3/4" water line check valve as the old one was cracked. I think this line has something to do with circulation pump. Its 2 days until it arrives, I went to Lowes and bought a 3/4" plastic coupler to hold water in the tub until new check valve arrives. My question is, can I run circulation pump w/o jets like this? Just refilled tub and would like to treat the water w/ circulation pump running if possible. I've tried a few searches on web, forums, and the YouTube w/o any luck. TIA for any answers
Bonfire
« Last Edit: January 12, 2019, 04:27:33 pm by Bonfire »
Check Valve
Re: Check Valve
« Reply #1 on: January 14, 2019, 01:15:13 pm »
As long as the circ pump is working you'll be fine without that check valve. Its there so that if the circ pump stops working the water doesn't move back up the hose into the ozonator.
Bonfire
Re: Check Valve
« Reply #2 on: January 16, 2019, 04:15:55 pm »
Thank you
Re: Check Valve
