Author Topic: Help selecting a pump  (Read 1632 times)
Termin8or23
« on: January 10, 2019, 02:20:25 am »
https://photos.app.goo.gl/WwmiwWckkZ64om8FA
Hello,
I’m restoring an  old hot tub that was  given me. Was told everything works, just needs a pump/motor. I measured the pvc pipe. Both of them are  2” inside diameter. The model number of the hot tub was worn off as you can tell from the picture. But I believe the numbers up top may be all I need? Would greatly appreciate any help on to what pump I might need and possibly best place to order from? Thank you so much!
**Edit**
If you can’t view the image, the numbers on the hot tub read
240V 30A 60HZ 1ø 3 WIRE
           MCA 38A MOP 40A
If anyone could recommend a motor or website to get one that matches these specs, I would really appreciate it so much!
« Last Edit: January 14, 2019, 02:48:46 am by Termin8or23 »
