Author Topic: New hot springs flair questions  (Read 4132 times)
Eastside
« on: November 03, 2018, 10:06:00 am »
New hot tub owners for a week with our new flair.  Really stoked on it!   A couple questions. The interior led lights have a couple times have changed color while in use.   For example. We have the red interior light on low and suddenly then all switch to the white/light blue then all back to the red.  Kinda weird.   Its pretty random and only done it a couple of times.
Also, is there an auto off for the jet pumps on this hot tub, like a built in timer?  We had the tub on for a couple hours last night and both pumps turned off on their own.  They fired right back up when i hit the buttons to check.   Thanks for any info!
Any whooo,  sweet hot tub
bud16415
Re: New hot springs flair questions
« Reply #1 on: November 03, 2018, 10:38:19 am »
Not sure about your tub, but I would think the lighting should stay where you have it set. Our lights shut off after 4 hours or something like that if you forget and leave them on. Most tubs have one setting that runs thru all the colors also. What yours is doing I would mention it to the dealer.
As to the pumps yes they have an auto off setting.
Welcome to the forum and the world of hot tubbin.
castletonia
« Reply #2 on: November 03, 2018, 11:16:26 am »
Unless you have the lights setting to color wheel, they should stay on the color you have them set for.  As for the pumps, yes, there is a built in timer.  They will turn off automatically after 2 hours to prevent overheating.  If you are adding chemicals when you are done using the hot tub, just hit the clean button and that will run one of the pumps for 20 minutes.
Eastside
« Reply #3 on: November 03, 2018, 11:01:21 pm »
Thanks for the responses!  Will an eye on the lights and let dealer know
Botswana
« Reply #4 on: November 04, 2018, 06:58:05 am »
The LEDs switch unless you specifically set the color.  It's an option in the menus. Just look for something related to lights and mess with the setting. You can control brightness and what color is set
