Author Topic: Vanishing Act Pillow Use  (Read 2593 times)
arjunsud
« on: October 21, 2018, 06:09:24 pm »
Hello, could someone please tell me how to use the Vanishing Act Pillow with my Bullfrog A8 ? I am very confused as it says to put it by the heater return near the footwell and I do not know where this is .
Also it says something about not running jets while it is in place, how do I do this ? I didn’t think we could permanently disable the jets ? My Calcium Hardness is 325.
Thank you !
swilly1000
Re: Vanishing Act Pillow Use
« Reply #1 on: October 21, 2018, 06:40:26 pm »
Just take the pillow and hide it under your bed.  ;D
« Last Edit: October 22, 2018, 01:09:33 am by swilly1000 »
« Reply #2 on: October 22, 2018, 08:20:44 am »
No they work better in the rafters of the garage.
BullFrogSpasMN
« Reply #3 on: October 22, 2018, 11:15:15 am »
Just place it in the footwell area of the spa, jets can run on low speed, ie heat/filtration mode just don't run them on high. Moving forward I would source a portable water softener to fill/top off the spa instead of buying those overpriced pillows in which you may need more than 1 depending on how high your calcium level is....see here: https://www.portablewatersoftener.com/shop/water-softeners/portable-standard-water-softener?SKU=OTG4-StdSoft
edit: shop around, I've seen them for around $200-$250 on sale
arjunsud
« Reply #4 on: October 22, 2018, 11:44:15 pm »
Thank you very much !!
