Author Topic: Elite by Maax issue  (Read 1882 times)
tommyp
Elite by Maax issue
« on: October 08, 2018, 07:21:07 pm »
Need a bit of help. Drained and cleaned the tub today. Filled it, saw that the water falls aren't working right. Filled it through where one of the filters goes as was directed. For the sake of explanation we'll call the waterfalls left and right. Left was on full, right was on half, couldn't get either to turn off. Tried turning them on/off a few times, now left is on high, won't turn off. Right is trickling, won't get any pressure. Just for shits and grins I swapped the valves side to side. Took them out, with gaskets, knobs..all of it. Swapped sides anticipating that if it was the valves, after swapping left would barely trickle, and right would be on full.
The problem didn't follow the valves, leading me to rule that out. Any help would be appreciated.
« Last Edit: October 08, 2018, 07:44:00 pm by tommyp »
Elite by Maax issue
bradleyabell
Re: Elite by Maax issue
« Reply #1 on: October 09, 2018, 11:01:29 am »
Maybe someone else could help more, but I would call your dealer if I were you...Especially if tub is still under warranty!
