Author Topic: Beachcomber 320X - Circulating Pump  (Read 2129 times)
Militarycross
« on: August 06, 2018, 08:39:18 pm »
Greetings all. I've had our Beachcomber for nearly 20 years. It seems more and more like the circulating pump is running -- far more frequently than it did when we first purchased it. I could be wrong, but I thought it only came on twice a day. Can't remember.
My question to the Forum members is whether or not there is an issue here or an irritation. If it is a problem, what is the fix?
Thanks for reading and sharing your knowledge base.
phil
Re: Beachcomber 320X - Circulating Pump
« Reply #1 on: August 07, 2018, 07:15:04 am »
The pump is supposed to cycle during pre-programmed filtration cycles and any time the heat drops 2 degrees below the set point.
