Author Topic: Marquis Reward Wiring  (Read 4106 times)
Pavel
« on: July 18, 2018, 08:19:41 pm »
I had my electrician come by my place to take a look at my Marquis Reward and when we opened up the panel there was no pre-drilled hole or place to run the wiring to the exterior of the tub.
Please provide suggestions or how did you run the wire from your hot tub.
Thanks in advance for any help.
Re: Marquis Reward Wiring
« Reply #1 on: July 18, 2018, 09:26:20 pm »
There are 2 knockouts on each side of tub on comtrol panel side
Certified106
« Reply #2 on: July 18, 2018, 10:44:55 pm »
My Marquis definitely had two knock outs with one being on each side of the tub. Mine were two black plugs in either side
Pavel
« Reply #3 on: July 20, 2018, 05:47:47 pm »
From the knockouts, will the wire run directly into the control panel area or is drilling going to be necessary?
Certified106
« Reply #4 on: July 20, 2018, 06:00:57 pm »
No drilling was necessary but make sure you have about 2-3 foot of wire extending past the fitting on the conduit so you can witre it in to the control panel.
