Author Topic: Power trips and won't come back on  (Read 1617 times)
johnbriancunningham
« on: July 16, 2018, 03:32:14 pm »
Hello...I started up my hot tub this spring and when all the jets were running the power stopped.  The breaker had tripped so I reset the breaker but there was no power showing at the hot tub panel.  I had an electrician come out and he said power looked fine from the panel to the spa pack.  I contacted my hot tub technician and he identified that the main board was faulty.  He replaced it and for 2 weeks all was fine.  The the same thing happened again!  Has anyone had this experience before?  Any suggestions what could be causing this before I replace everything in my hot tub?  My technician is coming out again but I thought I would run this problem through this forum for ideas.  Thanks
Botswana
Re: Power trips and won't come back on
« Reply #1 on: July 17, 2018, 12:08:24 pm »
So the breaker isn't repeatedly tripping, the power to the tub just won't turn on? Didn't you check the interior breaker (main house panel?)
