Author Topic: Hot Tub Water Woes  (Read 5776 times)
Certified106
Re: Hot Tub Water Woes
« Reply #15 on: July 18, 2018, 01:26:08 pm »
Ok, well that gives me a little more peace of mind and I really appreciate the advice. I tend to not have enough patience and I am going to slow down on making adjustments an give everything a chance to adjust after making a small change. From what you all are telling me I definitely think I have been to reactive and aggressive with adjustments which may be why I have been fighting it so much. We will see what it lloks liek when I get home.
Honestly I'm just ready to get back in it as I have been missing using it and y wife has asked for three days when it will be done lol. It has hands down helped my back a ton especially using it in the morning.
Botswana
« Reply #16 on: July 18, 2018, 02:44:49 pm »
It probably didn't filter at all while you were gone because the actual temperature was well above set temperature. It's a safety mechanism.  I can't set my tub lower than 93 in the summer because the summer days keep it around 95 degrees and if it's 3 or more degrees above set temp, filter is suspended until it's within 3 degrees. Maybe just don't lower the temp when you leave next time.
Certified106
« Reply #17 on: July 18, 2018, 05:29:48 pm »
I totally agree with you! I don't think it ran other than the two hour circulations. I won't be doing that again that's for sure.
Certified106
« Reply #18 on: July 18, 2018, 10:42:30 pm »
And all was right with the world tonight........ 30 minute soak in a crystal clear hot tub with a glass of bourbon. ;
Got home tonight and the PH was in a good range with the TA being slightly high and the chlorine level perfect. I will check it again tomorrow and see what it is.
If the pH is good and the TA still slightly high would you all continue making slight adjustments over a period of time to see if you could get the TA down some?
URL=http://s1281.photobucket.com/user/certified106/media/IMG_20180601_211844_zps1tx4yhyp.jpg.html][/URL]
<img src="https://image.ibb.co/eyePBy/IMG_20180530_165045.jpg" alt="IMG_20180530_165045" border="0">
« Last Edit: July 19, 2018, 04:43:03 pm by Certified106 »
