Author Topic: Cleaning a bestway Vegas hot tub..  (Read 1582 times)
Jackson86
« on: July 10, 2018, 10:01:41 am »
Hey all filled hot tub shocked it ready for use change of circumstance means I was unable to.. left it for 2 weeks until today.. went out and along the rim of the hot tub is all stained yellow have tried white vinegar and baking soda no joy at all.. any suggestions or is it a new inflatable liner needed?
« Last Edit: July 10, 2018, 10:04:21 am by Jackson86 »
mek
Re: Cleaning a bestway Vegas hot tub..
« Reply #1 on: July 10, 2018, 06:22:28 pm »
Could try 12% peroxide gel designed for hair coloring under food covering "cling" film out in the sun.  It's just another (highly effective)  form of bleach.  Get some good masking tape like the plastic duck brand masking tape and tape this film or a cut up food freezer bag around stain on 3 of 4 sides. Leave it 30 -45 minutes, clean off and reapply.If you let it bubble out from your film the peroxide will dry and your stain is simply moved. A pipette if you have one is good for injecting the peroxide gel under the film
I read somewhere that UV make the peroxide 30x as effective. Do not mix this with Vinegar or Chlorine bleach. The former makes mustard gas and the latter will foam up and could explode in your face...!
