Author Topic: Can you help me identify a "new to me" hot tub?  (Read 2424 times)
Jennsky
« on: May 14, 2018, 04:48:12 pm »
I recently purchased a used hot tub from kijiji and it is due to be delivered tomorrow.  I do not know the make of it, and I should probably find that out in case I need to fix anything.
I am hoping someone here can help.
Please?  Thank you
Jenn
Hopefully this works, I am new to this forum and as with the hot tub, have no idea what I am doing :)
https://drive.google.com/file/d/1XXN1-qfW3NMgs8MDiNSS4tWf5B5B-XCq/view?usp=sharing
https://drive.google.com/file/d/1gajbYLRwv38NIZfy2WkQ7GlqyfTJejhA/view?usp=sharing
https://drive.google.com/file/d/1qafxeOz6asSjWHg057NAnf1Zj60O5Ybb/view?usp=sharing
Re: Can you help me identify a "new to me" hot tub?
« Reply #1 on: May 15, 2018, 09:00:41 am »
No idea, but it's old.
Ghvf
« Reply #2 on: May 15, 2018, 04:52:48 pm »
Hydropool spas are made at your location on the serial plate, so that's probably what it is. Moving something that old brings a great chance of leaks. Try not to be discouraged...it could be in great shape internally. A spa tech will be able to tell you for a nominal fee.
« Reply #3 on: May 15, 2018, 06:22:28 pm »
  They haven't been around that long.  ;)
   Either way it's not so much the brand of spa it might be, but the equipment they used in it.  Which should be easy to replace if needed.
« Reply #4 on: May 15, 2018, 06:34:41 pm »
Still not as viable option as patiently searching to find a good-running used spa on craigslist.
