Author Topic: How much does your hot tub cost to heat 24/7 a month  (Read 6016 times)
Beck0101
Re: How much does your hot tub cost to heat 24/7 a month
« Reply #15 on: May 01, 2018, 09:25:25 am »
A 220 wired hot tub heats on average 5 to 7 degrees an hour. Cost per month to run the tub should be around 30 to 50 dollars. Where you live and how much you use the tub are variables.
How the tub is wired doesn't really, technically, impact the rate of heating.  The capacity of the tub (gallons) and the size of the heater (watts) is what determines how quickly the tub can be heated (not taking into account the nebulous stuff like insulation, plumbing, pumping, covers, heater efficiency, etc).
If you have a 500 gallon tub with a 4000 watt heater you can raise the temp of the water by just over 3 degrees per hour assuming a 100% duty cycle on the heater.
TubbinLuvin
« Reply #16 on: May 01, 2018, 12:44:32 pm »
Man .... these prices are higher than I hoped
I don’t plan on getting a huge jacuzzi anymore
One with 3 pumps or whatever , like the 6 seaters have
Here’s the newest jacuzzi I’m looking at the Bullfrog R5L
Was told a little over 6000.00 for that at my local dealer
Steps ,cover, chemicals and ozone added in that price
Is that a good price for this ?
And does anything in the specs stick out as generic
https://www.bullfrogspas.com/spas/r-series-hot-tubs/r5l/
I know I’ve said it already a lot but im very thankful
for all of your wealth of information that is here on this wonderful site
Now that thing shouldn’t cost much to heat 24/7 during Feb to November.....right ?
Beck0101
« Reply #17 on: May 01, 2018, 03:13:13 pm »
Don't take this the wrong way but if the difference of $50 a month is impacting your decision to buy a spa, you probably shouldn't be buying a spa.  Or maybe keep an eye out for a used spa that can be had for much less money?  They are out there on craigslist all the time.
TubbinLuvin
« Reply #18 on: May 02, 2018, 10:31:28 am »
That’s not really the issue
I’m just wanting to prove to my girlfriend
That having a jacuzzi won’t hit us hard on the electric bill
bradleyabell
« Reply #19 on: May 02, 2018, 01:13:10 pm »
Also remember the costs to maintain it as well...Chemicals, filters, etc.
