Author Topic: How much does your hot tub cost to heat 24/7 a month  (Read 6540 times)
TubbinLuvin
« on: April 26, 2018, 09:43:06 am »
I’m being told multiple things by dif manufacturers
One said only 13 a month and another said about a dollar  a day
Re: How much does your hot tub cost to heat 24/7 a month
« Reply #1 on: April 26, 2018, 09:56:43 am »
It depends on a lot of things. How much you use it, climate you are in, electric rates you pay and things like that. Also depends on brand. Some insulate better then others
castletonia
« Reply #2 on: April 26, 2018, 10:07:33 am »
Ask what criteria was used to arrived at $13 a month.  $1.00 per day in my opinion is far more accurate for the best insulated brands unless your in a warm climate.
« Reply #3 on: April 26, 2018, 10:57:52 am »
One is being far more honest than the other or maybe one is just far more informed than the other. I think you know which is which.
Beck0101
« Reply #4 on: April 26, 2018, 12:05:36 pm »
I believe I can trend below $20 a month during summer with my A8 even whilst keeping it above 90 degrees.  In the dead of winter I should be right around the $40-45 range at 100/101.
I'm in Michigan.  And the Bullfrog I own "should be" one of the better performing models out there from an energy efficiency standpoint.  I would not be shocked if a lower-end spa in my climate was pushing $80+ a month in February...
guardrail22
« Reply #5 on: April 26, 2018, 04:31:24 pm »
I. Have a meter on the power to my 965L. 535 gallons. And the extra insulation package. Water temp set to 100F and filtering 2 hours out of 12. An hour north of Durham NC.
On a co-op with tiered rates. Since December when we got it, cold months about 500-550kwhrs at marginal rate 7.5 cents. So $35 or so.
Upcoming summer months rate goes up to 9.5 cents but kwhrs should come way down.
« Reply #6 on: April 26, 2018, 04:39:26 pm »
On another thread you are talking about not having enough chlorine with @ease. Part of your problem is most likely not enough filtration.
« Reply #7 on: April 26, 2018, 08:13:27 pm »
The only way to know is to meter your tub, not that complicated. A well insulated tub 20-30 per month average. Not so well insulated 50-60 or more.
13 bucks a month if you don't use it, keep it covered and turn the temp down to 70 and your local climate stays above 70 deg.
TubbinLuvin
« Reply #8 on: April 30, 2018, 11:18:20 am »
Thank you for all of your replies
The thing is , I live in the Midwest
If I was to heat it 24/7 But was only to keep it
At around 95 degrees when I’m not in it
How long would it take to get from 95 to 103-104
If it was too only take 1 hour to go from 95 to 103
Then I’d be fine with that . I’d prolly want to get in it
Once per day for around 25 minutes
Boy this forum is a godsend
bradleyabell
« Reply #9 on: April 30, 2018, 11:48:43 am »
On average I would say around 3 degrees an hour it takes to bring up the temp of the tub.  I have a Bullfrog X7L that's less than a year old and I am willing to bet my tub is costing me around $60-100 a month extra keeping it between 101-103 degrees, 24/7 throughout the Michigan winter.  That being said...We do use it almost every day for at least 30 minutes.
richierich
« Reply #10 on: April 30, 2018, 11:58:53 am »
A 220 wired hot tub heats on average 5 to 7 degrees an hour. Cost per month to run the tub should be around 30 to 50 dollars. Where you live and how much you use the tub are variables.
« Reply #11 on: April 30, 2018, 03:26:43 pm »
There's no way it's costing you that much.  Unless maybe you leave your cover off for extended periods of time or some other strange factor.....
« Reply #12 on: April 30, 2018, 06:12:54 pm »
60 bucks or more is common here in the midwest in the winter. The summer can be better at 30-40. The only ones I see do better here in the midwest winters are Hot Springs, D1 or other fully foamed tubs with circ pumps.
bradleyabell
« Reply #13 on: May 01, 2018, 07:22:48 am »
My highest ever energy bill (gas+electric) before the hot tub was only around $175...I had a bill over $300 this winter.  I ALWAYS leave the cover on, unless we're in the tub or I'm shocking it or adding chemicals etc.
Beck0101
« Reply #14 on: May 01, 2018, 09:09:58 am »
If that was in January (Feb bill) that was not a typical energy month in Michigan.  If you think you're paying $100 a month consistently in the cold months for your X7 in Michigan you need to start trouble shooting.  You might have a pump running 24/7 or messed up filter cycles.  No way it should cost this much...
