Author Topic: Pea Gravel or Concrete  (Read 3790 times)
pcaulfi
« on: September 01, 2004, 02:42:53 pm »
Sorry, if this has been beaten to death already, but a quick search didn't turn it up.
I just bought a new tub, to be installed next week. I am planning on setting it on a pea gravel base (dealer called it a sand box install).
What do you think? Should I use an EZ-Pad on the gravel?
Pat
PPOL
Re: Pea Gravel or Concrete
« Reply #1 on: September 01, 2004, 02:52:39 pm »
What is the size and filled weight of the tub?
Larger tubs (5000-6000 lbs filled w/6 people) we suggest a 10X10 4" concrete reinforced slab.
If you are talking about a smaller tub, pea gravel should be fine.  I have had a customer install a Caldera Martinique on pea gravel with no problems.
Personally, I would go with a slab less likely to go off level.
Good Soaking,
Neil O'Donovan
Phoenix Park Outdoor Living
Wilmington, NC
OhWhyNot
« Reply #2 on: September 04, 2004, 05:33:23 pm »
hello,
I was surprised to hear the same 'sandbox' suggestion when the HS guy came to survey our tub location, but a few folks here assured me that it was indeed a viable option.
We plan on building the sandbox real soon!
-E  :D
