Author Topic: Caldera Vanto Filter Pump Settings  (Read 3301 times)
araize
« on: April 04, 2018, 08:53:29 pm »
I just got a Caldera Vanto with an ozonator. What is the recommended setting for the two pumps? My dealer recommended 6 hours for each pump. Is that correct?
Re: Caldera Vanto Filter Pump Settings
« Reply #1 on: April 04, 2018, 10:46:21 pm »
It’s not each pump. It’s set by hours on each filter setting. I usually have my customers start at 2 on both and adjust as needed. 6 is way overkill
bradleyabell
« Reply #2 on: April 05, 2018, 08:18:01 am »
I have my tub set to 4, (Live in Michigan) but during warmer months I'll move it to 2.
araize
« Reply #3 on: April 05, 2018, 08:25:41 am »
Thanks so much for your replies!  I'm located in Chapel Hill NC with mild temperatures in the winter/spring. The pumps have been running for more than 12 hours. They recommend 6 hours per filter pump for the ozonator to work its best. Is that true? Very confusing! Thanks for your help!
« Last Edit: April 05, 2018, 09:04:57 am by araize »
« Reply #4 on: April 05, 2018, 03:33:33 pm »
The more the pumps run the more effective the ozone will be.....but I still think that's way overkill.  The other thing you will probably run into running it that much is in the warmer months (june-Aug) the tub will probably overheat.  I wouldn't run it that much
araize
« Reply #5 on: April 06, 2018, 11:47:25 am »
Thanks hottubguy. I reduced the pumps to 3 hours each. Do you recommend 4 hours? Thanks.
castletonia
« Reply #6 on: April 06, 2018, 01:18:37 pm »
I recommend to my customer 3 hours each filter cycle, so 6 total.  I have had a few that had to bump to 4 hours each cycle and some reduced down to 2, all depends on usage.
