Author Topic: Chem Lab 101  (Read 3026 times)
Warkovision
  • West and Wewaxsation, at Wast!
Chem Lab 101
« on: September 01, 2004, 02:48:10 pm »
Tested water again this morning after adding dichlor and protect plus to the new water yesterday and 3 of us soaking last night. pH was off the chart toward the base side (over 8.0) :o  The non treated fill water yesterday read 7.2 with total alkalinity and hardness both at 120.Those (TA and CH) remain the same today. I added 1 1/2 tsp. of pH Down and ran the jets for a 1/2 hour. Still off the chart. ??? Added one more tsp and decided to just let things sit. Now I'm reading about false pH test result possibilities in the Taylor book from too much chlorine. Holy Cow. Maybe I should just take a Zen approach for awhile and only observe. :)
« Last Edit: September 01, 2004, 02:49:14 pm by Warkovision »
Chem Lab 101
Re: Chem Lab 101
« Reply #1 on: September 01, 2004, 04:29:55 pm »
Let things settle for the night.  In the morning when the chlorine levels are low, check and adjust the pH only.  TA and hardness are fine.  After water is balanced, check and adjust once per week.
Warkovision
Re: Chem Lab 101
« Reply #2 on: September 02, 2004, 02:33:11 am »
This whole process is becoming a fascinating exercise in interpretation. My pool man was here this afternoon and I caught him in time to discuss water chemistry. He said, "let's have a look" and used his kit and reagents. He said my pH was 7.6 according to his kit. I performed the same test with my Taylor Pro kit and read 8 or over. He looked at the taylor tubes which have a color guide next to them and said he thought the color gradations were all too close. He uses something called GuardX? It was a lot easier to read. Then I took a sample into my dealer along with my strips and Taylor kit. My strips and kit both read 8 or over again, but his computer analysis machine said 7.6. He looked at the strips that came with my startup kit and noticed they had expired over a year ago! He gave me a new tube of strips and used one to check pH. I looked at it and it looked close to the 8.0. He said the way he does the strips is anything that doesn't look like the most extreme (RED) is probably OK.  Anyhow, I'm going to move cautiously when adding chems.
Re: Chem Lab 101
« Reply #3 on: September 02, 2004, 09:59:33 am »
« Last Edit: September 02, 2004, 10:02:11 am by wmccall »
Re: Chem Lab 101
