Author Topic: Upgrading Hottub  (Read 6031 times)
Re: Upgrading Hottub
« Reply #15 on: April 02, 2018, 03:51:16 pm »
 Yes there is, either a o-ring or a flat ring with raised o-ring molded into the flat part.
  It might be there, but just old and not sealing right.
« Reply #16 on: April 02, 2018, 04:40:47 pm »
And use a good gasket lube while your at it. Majilube.
Matt132
« Reply #17 on: April 03, 2018, 03:30:49 pm »
Thanks guys!
The rubber ring is there and is till in good condition. I think it wasn't sitting flush when i lined the pipe up with the pump so ive had to put a packer under the pump. Will try it tomorrow as the weather was horendous for working outside today!
Matt132
« Reply #18 on: April 17, 2018, 03:17:50 pm »
Update*
I ordered a new Lx Flow type Heater and a new circ pump.
There is pressure switch lead that comes from the heater. Does anyone know where to wire the 2 cables into? Is it just a positive and negative and i can link it in to the main powere feed cables?
<a href="https://ibb.co/gxSFZ7"><img src="https://preview.ibb.co/mMXhE7/20180417_200806.jpg" alt="20180417_200806" border="0"></a>
<a href="https://ibb.co/gAZJnS"><img src="https://preview.ibb.co/buDpu7/20180417_165504.jpg" alt="20180417_165504" border="0"></a>
Matt132
« Reply #19 on: April 17, 2018, 03:21:32 pm »
