Author Topic: GFCI Tripping Help  (Read 2515 times)
stang233
GFCI Tripping Help
« on: February 15, 2018, 11:29:52 pm »
I have an Artesian (South Seas Spa 746L) tub that was working great. We moved it and now it is tripping the GFCI. Balboa Board MVS504SZR1B
Tub is currently tripping the GFCI. The GFCI was checked and is good.
Disconnected tub and turned power on at GFCI and it did not trip. GFCI only trips with tub wired.
Checked for fault from all wires to each other and no fault.
Disconnected heater (OHM checks okay) and turned power on with heater disconnected and it would still trip GFCI
Disconnected ozonator  still trips.
Disconnected primary pump still trips
Disconnected secondary pump still trips.
I OHM checked the board and there is Zero ohms from Red to Neutral but 34 Ohms from Black to Neutral. Is the board faulty?
GFCI Tripping Help
castletonia
Re: GFCI Tripping Help
« Reply #1 on: February 16, 2018, 10:50:54 am »
Disconnect heater and see if it still trips.  I have also seen electricians wire them wrong.  Neutral should go to the breaker, not ground bar.
Astropin
« Reply #2 on: February 16, 2018, 02:47:19 pm »
Yeah double check the neutral at the breaker. Mine was just wired wrong yesterday and that was the issue. Neutral from tub need to be connected directly to the breaker and the white "piggy" from the breaker is connected the the neutral bar in the box. Make sure all the grounds are connected correctly as well.
« Reply #3 on: February 16, 2018, 06:14:07 pm »
I would try a board. Sounds like you did everything else right. How long after you reset it does it trip?
Thisismyname
« Reply #4 on: February 16, 2018, 08:01:16 pm »
Exactly this....
I returned 3 breakers thinking it was that but turned out it was the neutral wire connected wrong.  Assuming its a 4 wire set up.
Botswana
« Reply #5 on: March 28, 2018, 11:35:14 am »
I don't like when people don't follow up on whether they fixed the issue or not :x  Any remedy found?
