Author Topic: Heating issue  (Read 6092 times)
jeaves726
Heating issue
« on: February 06, 2018, 05:06:19 pm »
We have an Artesian Spas Waikiki hot tub (500 gallon).  It has 3 pumps for jets, a circulation pump, and the ozonator.  About a week ago, we noticed that the temp was down more than usual.  We keep it in standard mode and around 99 degrees.  When I turned up the temp, it started a cycle and about 45 seconds later, it started warming.  After I felt the warmer water coming out, I thought maybe it was just hung, so I started the jets.  The temp/heat light stayed on when I turned on the first and second jet pump.  When I turned on the third jet pump, the heating immediately shut off.  The circulation pump was still running, but it stopped heating the water.
I turned off the jets and changed the temp which started the cycle over.  It started heating and produced the same result when I turned the third jet pump on.
I thought it was just "jet 3" that was the problem.  Then, I started the temp cycle over.  When it started heating, I turned on "jet 3" first and the temp light stayed on…with warmer water coming out.  I turned on "jet 1" with no issues as well.  When I turned on "jet 2" the heat light immediately turned off and the water stopped heating.
So basically, no particular jet pump is the problem, but the heating/temp kicks off as soon as all three jet pumps are running.  It's never done this before….what could this be?  I can't find anything on this type of problem anywhere.  I also talked to a repair guy with quite a few years experience and he said he's never heard of anything like that.
Heating issue
castletonia
Re: Heating issue
« Reply #1 on: February 06, 2018, 05:39:17 pm »
Usually with that many pumps, unless you have a 60 or 70 amp breaker, there is not enough power for everything to run at once.  I cannot speak for why it is all of a sudden doing this though.
jeaves726
Re: Heating issue
« Reply #2 on: February 06, 2018, 06:02:39 pm »
Yeah,  if it was new, I would agree.  We've had the same setup for about 5 years now and of course it's "just out of warranty" according to the repair place.
Let me ask this....
About nine months ago, we had an issue with the circulation pump.  They came out and said the pump was under warranty replacing it with a new(ish) pump.  This pump had a year warranty on it at that time.  About three months after they installed the new pump, I called them to come back out because it was not circulating correctly.  It started out fine right after the install, but then ran less and less.  It got to where the pump wasn't running much at all on the temp cycles.  The place sent a different guy out to check the pump and possibly replace the bad part.  What the second guy found is that when the first guy replaced the part, he incorrectly plugged the new(ish) circulation pump into the audio power plug on the main board.  I don't know the exact voltage difference, but he said the audio plug supplies significantly less amperage/voltage than the circulation plug and that the pump had been running at a lower voltage than it should for the last six months causing it to fail.  He plugged it into the correct plug on the main board and said there was no damage to the circulation pump. Because of the error, they extended the warranty on the new(ish) pump for a year from that date.
My question now is could that have caused voltage issues on the main board?  The pump was trying to pull more power through a low power port causing some type of damage to the board...maybe?  I understand enough power stuff to be dangerous, but not enough to know if that's a possibility.
Hopefully that makes sense.
Re: Heating issue
« Reply #3 on: February 06, 2018, 06:32:49 pm »
 The audio plug, for like a stereo?    Seem to me that would be 12v and no way run a 110v circ pump.   Makes no sense, unless the transformer for the stereo plugs into it that, then drops it down from 110 to 12v for the stereo?
  Are you sure the heater has always been on with all three pumps running.    Even the original Jacuzzi J-385 3 pump spa in 60amp would shut the heater down when all three were on.   But would stay on if pump 1 was only in low speed with the other 2 pumps on.
 If so is their a jumper on the board the tech might have changed and are you on a 60amp breaker?
  The other issue with the spa being colder than normal, if the circ pump was running it should heat the temp to what ever temp you set.   It doesn't just run all 3 pumps at the same time by itself.
jeaves726
Re: Heating issue
« Reply #4 on: February 06, 2018, 06:51:30 pm »
Yep, the power plug for a stereo.  We didn't get the model with the built in stereo so the plug on the main board is open and is the same connector as the circ pump.  I'm not sure about a transformer, but the repair guy said that the audio plug supplies enough voltage/amps to power up the pump but not to fully run it...which was why it turned on and worked initially.  He said it worked on a volt meter when the first guy was there installing it but over time couldn't run at the lower voltage causing it to stop cycling like it should.
. Yeah,  it would heat with all three on.  Even the repair place said it should still be heating with all the jets running.  I just went out and checked the breaker.  It's a 100 amp.
My understanding with our model (which could be completely wrong), is that the circ system is separate from the jets (outside of all being run by the same main board).  The circ system turns on during the temp cycle.  The hot tub as a separate process will turn on all three jet pumps to circulate the water and run a cycle every so often as well, but it isn't to heat the tub.
« Last Edit: February 06, 2018, 07:03:42 pm by jeaves726 »
Re: Heating issue
« Reply #5 on: February 06, 2018, 09:08:44 pm »
  So the breaker out at the spa is 100Amp?
jeaves726
Re: Heating issue
« Reply #6 on: February 06, 2018, 09:10:48 pm »
Yep it is.
Sorry about the message. I tried to reply to this and somehow sent a message instead.
Re: Heating issue
« Reply #7 on: February 06, 2018, 09:57:11 pm »
  Pretty unusual!   You running lights or other outlets off of it?
jeaves726
Re: Heating issue
« Reply #8 on: February 06, 2018, 09:59:55 pm »
Nope. It has LEDs built in it but we typically don't use them. No other accessories. Just the jet pumps and circ.
Do you think the main board could be damaged by the low voltage deal?
Re: Heating issue
« Reply #9 on: February 07, 2018, 05:35:03 am »
Low voltage to a pump won't ruin the board. If anything it would effect the pump but lower than required voltage wouldn't ruin a pump. Higher than required yes. A 110 volt pump will not run on 12 volts. Was the radio plug 12 volts?
Are you sure the amperage at the breaker is consistent?
Re: Heating issue
« Reply #10 on: February 07, 2018, 09:56:55 am »
  I meant like deck lights or outlets around a deck.
jeaves726
Re: Heating issue
« Reply #11 on: February 07, 2018, 04:56:16 pm »
Oh, I got ya.  Nah, it's on it's own breaker with nothing else tied onto it.
jeaves726
Re: Heating issue
« Reply #12 on: February 07, 2018, 06:13:35 pm »
Everything (mostly) has worked for five years with this tub.  It's always heated while running all three jet pumps.  The circ cycle turns on something like 8 times in a 24 hour period (I think). And, the jet pumps turn on a few times in the 24 hour period too.  The only exception was when the circ pump plugged into the stereo plug and it wouldn't run correctly.  It's just odd to me that it's been fine that whole time, then they hook something up incorrectly and all the sudden, the board is going bad.
It also doens't look great that when the company checked their paperwork, it was documented that the pump was hooked up correctly...after the second guy came out and told us it was wrong.  He logged it on his paperwork, but somehow that got changed after he left our house.
Re: Heating issue
« Reply #13 on: February 08, 2018, 05:55:27 am »
If you could check if that radio plug is 12 volt we would know. A pump inadvertently plugged into a 12 volt plug would mean the pump wouldn't work. But it wouldn't ruin the board. But a bad pump plugged into the wrong 120v plug may ruin the board.
jeaves726
Re: Heating issue
« Reply #14 on: February 08, 2018, 06:49:22 pm »
Just talked to the spa place.  They are saying there's no way it could cause the board to go bad but they've also never really seen the board go out like that either.  Hmmm...
He gave me two options. Change the main board out for around $500 or Try to change the circuit breaker for around $100.  He said that even if the breaker is not tripping, it could be giving the tub low power on the heat cycle.  I can't make that make sense in my head...if the breaker was the problem, it would trip.  If it was causing lower than normal power, it would show up in other ways in addition to the heat.  The ONLY time the heat kicks off is when a third jet pump is activated.  Nothing else is going crazy on the tub...the led lighting works without any issues (I realize that's extremely low voltage compared to the pumps, but if it's kicking off low voltage stuff to run the higher voltage stuff...)
My fear is that we would replace the main board and it not be the problem.
Re: Heating issue
