Author Topic: Filter Cleaner  (Read 3087 times)
nicker
Filter Cleaner
« on: August 24, 2004, 01:28:22 pm »
Well tomorrow will be one month with our tub and time to do a solution cleaning.  The cleaning product at the tub store is $10.95 CDN for 1 litre so I would get to months out of it.  I have heard that people use TSP and that it is the exact same as the cartridge cleaning solution you buy at the spa stores.  Is this true. I can get 4 litres of TSP for $5.95 so 4 months worth.    I would be worried that it would cause damage to the filters and tub.   I am buying an extra set of filters so I can do a swap each month.
Thanks for you help in advance
Filter Cleaner
HotTubMan
  • My 2.1 cents, eh
Re: Filter Cleaner
« Reply #1 on: August 24, 2004, 04:29:54 pm »
Never heard of TSP, cant really comment. Can you elaborate?
Re: Filter Cleaner
« Reply #2 on: August 24, 2004, 04:38:11 pm »
Some folks use TSP to clean filters.  I prefer filter cleaner made for the purpose.  I use a filter flask and keep my filter cleaner solution for four months.  I clean my filters on a monthly basis.
Re: Filter Cleaner
« Reply #3 on: August 24, 2004, 05:24:44 pm »
I'd follow Tony's advice. In the grand scheme of things the cleaner will cost you little and do a good job of getting your filter clean. One thing to add, make sure you do a very, VERY thorough job on your final rinse so you don't get any cleaner in the spa.
huh?
  • "42"
Re: Filter Cleaner
« Reply #4 on: August 24, 2004, 05:53:38 pm »
Something else I have noticed...don't soak them too long.  The detergents in the solution can eat away the plastic of the filters.  You will notice this because blue junk will continue to gunk up your filters.
stiffy
Re: Filter Cleaner
« Reply #5 on: August 24, 2004, 06:02:38 pm »
My dealer instructed us to soak in bleach over night.
Is this good or should we get the filter cleaner?
Should you rinse inside out or vis-versa.
Re: Filter Cleaner
« Reply #6 on: August 24, 2004, 10:09:55 pm »
To follow up on Spatech tuo's post, the worst foam problem I ever had was the first time I cleaned my filter and didn't get all the cleaner out.  It took forever to get rid of that.  Come to think of it, that was the only time I needed to use foam down.
« Last Edit: August 24, 2004, 10:10:38 pm by tony »
Re: Filter Cleaner
