Author Topic: Hot Tub Water Capacity Accuracy  (Read 2022 times)
spa_owner99
« on: January 26, 2018, 01:07:22 pm »
Hi,
As I navigate treating the water in my hot tub, I noticed my Artesian Captiva is listed on their website as a capacity of 400 gal.  When my local hot tub store delivered the tub they told me to set the Spa Frog to "2" which is for 300 gal hot tubs.  Assuming it's filled to headrests as stated in the manual, should I base my calculations on 400 gal.?  If so, any thoughts on why the store would be recommending the wrong Spa Frog setting?
Re: Hot Tub Water Capacity Accuracy
« Reply #1 on: January 26, 2018, 01:22:16 pm »
Hi,
Are you using bromine or the @ease?  Does the tub have a circ pump or does it filter off the main pumps?
spa_owner99
« Reply #2 on: January 26, 2018, 01:38:12 pm »
I'm using the SmartChlor @ease and I believe it's using the main pumps to circulate, but per the website, "The WhisperPure ™ Circulation System circulates water through the micro filters and the heater up to 100 times a day. It delivers clean, regulated water 24 hours a day with a low operating cost."
« Reply #3 on: January 26, 2018, 02:12:46 pm »
With tubs with circulation pumps I keep it set a bit lower then they recommend without circ pumps I follow the @ease recommendations
spa_owner99
« Reply #4 on: January 26, 2018, 02:27:10 pm »
Makes sense, thank a lot.
