Author Topic: Wiring for a Tiger River spa Bengal model m  (Read 4132 times)
Summer
« on: November 21, 2017, 10:57:57 am »
I recently bought a Tiger River spa and my friend helped me hook it up and do all the wiring. He also is an Electrician.  Before I read the manual he hooked it up to a 50 amp breaker in a sub panel. But also to a 50 amp breaker at the Shut off.
My problem is that the heater won’t totally heat the tub and I can’t seem to get water in the tubs.  The manual said to hook up a 20 amp breaker for the jets and a 30 amp breaker for the heater.   Is that why it is not heating enough. Because it’s hooked up
To a 50 amp breaker instead of
the separate 20 and 30 am breaker?
Beck0101
Re: Wiring for a Tiger River spa Bengal model m
« Reply #1 on: November 21, 2017, 12:19:13 pm »
So the heater is turning on and running but not heating the tub "fully"?  If the heater is coming on and you aren't blowing any breakers it certainly sounds more like a heater issue, not a wiring issue.  But I'm not an electrician...
« Reply #2 on: November 21, 2017, 12:29:41 pm »
When electricians hook up a spa like this based on how they think it should go this is often the result. You need to follow the wiring diagram specified in the manual!
