Author Topic: Circulation pump troubles  (Read 2925 times)
Ssgoytil
« on: October 20, 2017, 05:27:50 pm »
Hello I have a jacuzzi J320 and I notice after same time like 8 hours or more the circulation pump has stopped. If I push the jet button everything works I tested it and got 240 on both jets and circulation pump. But I push the button off no power to the pumps and I lose heat the circulation pump is for 24/7 circulation and heat. I tried new filters, flow switch’s running out of ideas.
Re: Circulation pump troubles
« Reply #1 on: October 20, 2017, 09:23:09 pm »
 Hold the plus and minus btn down for 5 to 10 seconds.   The screen will display F1 F2 F3 and so on.   If it's above F3 it's in an economy mode where it will only heat during a filtration cycle..    Worth a try.
Ssgoytil
« Reply #2 on: October 21, 2017, 07:51:56 pm »
Thank you that helped with the heating issue now every time the circulation comes on it pops a fl1 code. I looked at the flow switch when the circulation pump comes on and it trips just before contact after that it heats and is normal but is that normal.
Ssgoytil
« Reply #3 on: October 21, 2017, 07:57:51 pm »
I replaced the flow switch and new filters the circulation flow seems good to the feel and stays in contact with on switch but just takes like 4 seconds  to start up to make contact but still throws fl1 code.
« Reply #4 on: October 21, 2017, 08:25:07 pm »
  Unplug the flow switch plug from the circuit board. Wait 5 min then plug it back in.
« Reply #5 on: October 21, 2017, 09:20:45 pm »
How old is your tub?
Ssgoytil
« Reply #6 on: October 21, 2017, 10:32:28 pm »
2003
« Reply #7 on: October 22, 2017, 07:13:06 pm »
2003
Has the circ pump ever been replaced? If not they don't last forever and getting 14 years is a good thing. But you may want to replace it.
Conine2965
« Reply #8 on: October 23, 2017, 10:09:45 am »
Make sure to clean impeller good most circ pump issues are from clogs.
Ssgoytil
« Reply #9 on: October 25, 2017, 07:39:52 am »
Thanks I will look into replacing the pump when drain the tub.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #10 on: October 26, 2017, 01:25:03 pm »
Some of the circulation pumps take a couple of seconds to get up to speed.  As long as it does come on every time and heats, then it is fine.
