Author Topic: Scum issue  (Read 4831 times)
bradleyabell
Scum issue
« on: October 13, 2017, 05:51:34 pm »
Hi guys. I was out of town for 4 days. Came back and shocked the spa and added defoamer (it was very foamy) and clarifier. I went back to check on the tub about 15 minutes later and there’s this white and yellow/orange colored scum. Almost looks like wet shriveled up toilet paper. Any advice on how to eliminate now and or prevent in the future?
Scum issue
Clarkp
Re: Scum issue
« Reply #1 on: October 13, 2017, 06:13:31 pm »
Go to Amazon and get a two-pack of these genius little doo-dads.
Rola-Chem Scumbug Oil Absorbing Sponge
You will be shocked at how well they work... well, those and a sequestering agent...
Conine2965
Re: Scum issue
« Reply #2 on: October 13, 2017, 07:01:44 pm »
I use those and scum out from s pa depot
bradleyabell
Re: Scum issue
« Reply #3 on: October 13, 2017, 07:45:52 pm »
I already have a scum bug and it works great, but in this instance it didn’t help much at all.
bradleyabell
Re: Scum issue
« Reply #4 on: October 13, 2017, 07:47:22 pm »
Do you mean the zorbo??
Conine2965
Re: Scum issue
« Reply #5 on: October 13, 2017, 09:08:36 pm »
On spadepot.com scum out its an orange liquid. Works great.
meriflower
Re: Scum issue
« Reply #6 on: October 13, 2017, 11:06:55 pm »
It almost sounds like biofilm.  This is a new spa?
hottubdan
Re: Scum issue
« Reply #7 on: October 14, 2017, 01:04:00 pm »
It does sound like what we call white water mold.  If that is what it is, you will need a lot of chlorine (more than superchlorination) and some kind of spa purge.  Drain and refill.  clean filter.
The Wizard of Spas
Re: Scum issue
« Reply #8 on: October 14, 2017, 02:15:46 pm »
If it is white water mold, that just sucks.  There is a silver-based algecide that pool companies will offer if the remedy from hottubdan does not work.
bradleyabell
Re: Scum issue
« Reply #9 on: October 15, 2017, 12:02:54 pm »
Yes it is less than a month old.
Sam
Re: Scum issue
« Reply #10 on: October 15, 2017, 02:27:48 pm »
Definitely sounds like white mold.  Notoriously bad stuff.  You probably should perform a decontamination procedure.  There is one posted on here somewhere.
bradleyabell
Re: Scum issue
« Reply #11 on: October 16, 2017, 01:53:11 pm »
I don't think it was...It actually went away completely and my tub is now back to normal.  I do have a foam issue, but I believe it's because of friends getting in the tub with detergent residue on their suits.  I use defoamer and that solved the issue, but only temporarily.
Re: Scum issue
« Reply #12 on: October 16, 2017, 05:22:28 pm »
It's hard to get your friends to rinse their suits and shower before they go in your tub. You come off as a spa nazi.
Sam
Re: Scum issue
« Reply #13 on: October 18, 2017, 07:20:04 pm »
Well that's good.  Anytime I've seen something like what you described it required a decontamination which can be frustrating.
Re: Scum issue
