Author Topic: Pump / jet issue  (Read 1987 times)
bradleyabell
Pump / jet issue
« on: September 24, 2017, 09:18:20 pm »
 I just bought a bullfrog X Series Spa  started it up and pump one works perfectly pump to you did not work at all and by that I mean the pump sounds like it’s running but there was no water flow at all in the Jets.  I let water drip all of the valve and then I was able to get the Jets to run but it seems like it takes 5 to 10 seconds for certain jets on pump two to start and then once they stop there is a lot of bubbling coming out of those jets any advice or expertise that could fix my issue?
Pump / jet issue
Re: Pump / jet issue
« Reply #1 on: September 24, 2017, 10:58:46 pm »
 Most likely air in the lines, should bleed out pretty quick.
BullFrogSpasMN
« Reply #2 on: September 25, 2017, 11:15:17 am »
sounds like pump 2 has an air lock, you can remove the door panel, locate pump 2 then remove the bleed line to remove the air.
« Reply #3 on: September 25, 2017, 04:32:21 pm »
But be careful, it could get messy. I recommend running the pump for an hour. See if that clears it up.
BSFM is it a bleeder line or bleeder plug?
BullFrogSpasMN
« Reply #4 on: September 25, 2017, 05:20:40 pm »
They actually have both, standard "thumb screw" at the bottom of the wet end on the pump and then a bleeder hose attached via clamp at the top of the pump
