Author Topic: Yet another J-335 "FL1" error ..  (Read 2212 times)
dmosley
« on: September 15, 2017, 08:05:10 am »
My 6 year old Jacuzzi J-335 is showing the FL1 error code, no circ pump, no heat. Jet pumps will run. My questions:
Should the flow switch, with no water flowing, register as normally open or normally closed ??  It now reads open.
The circ pump does not even try to run - there is no voltage going to it.  If the flow switch is OK, could it possibly be a defective relay on the board (K3 ?) ?? Anyone had success just replacing the relay ? I would really rather spend $5 for a new relay than $500 to replace the board.
thanks a bunch,
don m.
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: Yet another J-335 "FL1" error ..
« Reply #1 on: September 18, 2017, 09:24:44 am »
If you have an FL1 and no power to the circulation pump, you have a bad relay on the circuit board.
Flow switch with no water should be open
Flow switch with flow should be closed
