Author Topic: where to buy hot tub furniture and bar stuff, towel drink holders  (Read 1862 times)
kimba
Hi everyone,  I found some things on Amazon to buy pool stuff , does it work just as well for hot tubs.  I need towel compartment, holder, bar attachment and little tables all need to be water proof.  Any special places you all may shop ??
The Wizard of Spas
Re: where to buy hot tub furniture and bar stuff, towel drink holders
« Reply #1 on: August 25, 2017, 01:31:55 pm »
A&B Accessories does nice, quality work with recycled material.  They build things specifically for hot tubs.
Leisure Concepts is another place to check out:  They do accessories that are quality, albeit not as attractive as A&B (but that is aesthetics and I just may have poor taste).
Hope this helps.  Good luck moving forward.
TEA POT
« Reply #2 on: August 28, 2017, 07:07:27 pm »
Any real difference between Leisure Concepts Safe-T-Rail II and CoverMate Spa Side Handrail with Base?   ???  ::)  :o
https://www.carefreestuff.com/mm5/graphics/00000001/7930-Spa-Handrail-MAIN.jpg
https://cdn3.volusion.com/hpjxf.wrqtg/v/vspfiles/photos/LC-STRII-BLK-2.jpg
I can appreciate paying for quality if there is a true difference in build or such...  8)
Need to get this ordered before this tub shows up...  ;)
Thanks for any advice
« Last Edit: August 28, 2017, 07:16:17 pm by John_Q »
The Wizard of Spas
« Reply #3 on: August 29, 2017, 03:29:11 pm »
I like the one that bolts to the cabinet vs the one that slides under the tub:  Yeah the bolting may turn people off but it is waaaaaay more sturdier than the one that slides under.  Plus, it rotates 360 w/o having to be screwed to tighten down every time.
TEA POT
« Reply #4 on: August 29, 2017, 04:49:07 pm »
I was considering adding the mounts up top as supplemental support with the one that slides under ;)  (Short & Stout Guy right here)  8)
https://www.hottubwarehouse.com/media/catalog/product/cache/2/image/9df78eab33525d08d6e5fb8d27136e95/s/a/Safe-T-Rail-5-2.jpg
