Author Topic: 2001 Sun Dance Tango  (Read 1576 times)
ChrisW
« on: July 28, 2017, 12:25:53 pm »
Hi All -
We have a 2001 Sun Dance Tango - stopped heating - FL1 error as well
Both Hi and Low works, bubbles included, light is fine - FYI
Replaced filter
Replaced flow switch
Replaced full heating unit
Bled all air out
Power off and on numerous times
Prior to all of this the circ pump died and I just bypassed with new hose - I was hoping to run without circ pump - is there anyway to "jumper" the circ pump out of the normal operation on the board or elsewhere?
« Last Edit: July 28, 2017, 12:28:59 pm by ChrisW »
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: 2001 Sun Dance Tango
« Reply #1 on: July 31, 2017, 10:44:07 am »
You would need to replace the chip on the circuit board  so that the heater activates the low speed pump.  You will also need to replumb the spa so that the main pump pushes water through the heater.  Would be way easier and cheaper to just replace the circulation pump.
