Original
Hot tubs and blood pressure, high and low
Pages: [
Topic: Hot tubs and blood pressure, high and low (Read 4592 times)
patepup
on:
August 12, 2004, 08:20:30 pm »
Any body experienced any problems with a hot tub regarding high or low blood pressure. I noticed myself when using a hot tub in a hotel i.e. that I get dizzy quite quickly. Should I be concerned about purchasing one? Thanks for your suggestings, patepup,
on:
bethshar
Re: Hot tubs and blood pressure, high and low
Reply #1 on:
August 12, 2004, 08:59:18 pm »
No one should stay in a very hot tub for long. If you had your own you can control the temperature!
empolgation
Full Member
you pay what you get it for
Reply #2 on:
August 12, 2004, 09:02:12 pm »
Dizziness is a common result of soaking too long in water that is too hot. As mentioned, you can set the temp of your own spa for what is right for you.
e
Global Moderator
Mentor Level Member
Reply #3 on:
August 12, 2004, 09:05:17 pm »
I have high blood pressure, and the tub actually helps that, but as others have mentioned you can over do it.
Tubber
Reply #4 on:
August 12, 2004, 09:52:14 pm »
When in a tub thats to hot or staying in to long at high temps it is referred to as hyperthermia. Just as dangerous as hypothermia.
Ultimate Member
Reply #5 on:
August 13, 2004, 12:20:47 am »
First and foremost, consult your doctor before making the purchase. No one here can give you complete information without knowing your medical condition or how a spa might effect that.
That said, can you have a bath? I'm guessing yes, which means that you can own a spa and enjoy the all the benefits without exceeding 98 degrees (body temp). Getting into a spa will tend to initially increase BP but as the heat starts to work, it increases blood flow and lowers BP.
patepup
Reply #6 on:
August 13, 2004, 08:23:56 pm »
Just a "thank you" to all that responded to my question. I am glad I found this place, I am sure I will be back with more, before I buy, I am eying the Sundance Marin, the local dealer wants $ 7800 but would give us a discount on a floor model. Any comments?
Mendocino101
Ultimate Member
never ask for what you are not willing to give
Reply #7 on:
August 13, 2004, 09:23:24 pm »
As Steve mentions....check with your Doctor....but you should be fine.....take your time and find the spa that is right for you......enjoy......
windsurfdog
Senior Member
Loving this cool weather....
Reply #8 on:
August 15, 2004, 10:05:53 am »
patepup,
$7800 sounds high for the Marin. Keep negotiating as well as looking/wet testing other tubs. Good luck!
Reply #8 on:
Pages: [
Original
