Author Topic: 2008 Maxxus "Filter Annunciator" error  (Read 2703 times)
Smoke_1
« on: July 05, 2017, 01:36:31 pm »
Hi all,
I checked on the tub a few days ago and noticed I had an error message. It was a flashing picture of a filter with a water drop superimposed over it. My manual calls it a "filter annunciator". It says, "clean or replace filter". Seemed simple enough. I replaced the filter. It's still flashing and I'm at a loss as to what else it might be talking about. Any help is, as always, greatly appreciated.
Thanks in advance,
John
Re: 2008 Maxxus "Filter Annunciator" error
« Reply #1 on: July 05, 2017, 03:33:36 pm »
Try shutting it down at the breaker for 10 minutes then turning it back on.
Smoke_1
« Reply #2 on: July 05, 2017, 04:38:13 pm »
Hey Tman122, I shut it down for 20 min. (that's what the store advised). It came back with the power. I was hoping that would reset the alarm. I figured between power off and new filter.... maybe that would work. Not yet. Is there another cause for that error?
Thanks for the help,
John
« Reply #3 on: July 05, 2017, 05:04:03 pm »
 If it is just the filter reminder and the spa is running fine, this should help.
 https://www.manualslib.com/manual/166594/Sundance-Spas-850.html?page=35
Smoke_1
« Reply #4 on: July 05, 2017, 05:19:17 pm »
Thanks Jacuzzi Jim, I'll give it a try when I get home.
Smoke_1
« Reply #5 on: July 10, 2017, 11:45:06 am »
Sorry it took so long to get back. You were right Jacuzzi Jim, it was just the reminder to "clean or change the filter". I followed the steps on the link you posted and it went away. I also noticed that the time was an hour off, so I looked up how to adjust it and right by there was a section on "how to set the filter reminder. Oops.
Thanks again for the help,
John
