Author Topic: Coast Spa Running costs - What you need to know  (Read 2906 times)
BoxieBoy
« on: May 21, 2017, 03:02:32 pm »
Anyone thinking of buying a spa here is some Accurate running coast and power usage information that I have gathered from my spa (European model) that may be useful.
Model: 330gal Coast Vantage Curve - full foam insulation with a 4" coast guard energy saver cover.
240Vac 50Hz supply.
Cable used - 6mm2 SWA on a dedicated 40Amp RCBO circuit plus a master isolator switch >2m from the tub.
Balboa system fitted with a 3kW heater (incorporating two flow/ temperature sensors A&B).
Fitted with two 7HP twin speed pumps.
Filtration (pump 1 low speed no heating) - 1.7Amp
Pump1 (low speed plus heating) - 14.5Amp
Pump 1&2 (low speed plus heating) - 16.5A
Pump 1&2 (high speed plus heater) - 29.5Amps
For approximate wattage just multiply Amps by 240.
I fitted a kWh meter to the circuit to get an accurate running cost
11April -11May average of 4 usages of 40 min per week.
Set temperature of 38 deg (ready mode)
5hr Filter cycle per day
Energy usage -  390kWh per month
UK energy pricing of 14.38P per kWh =£56 per month or 1.80 per day.
IMHO Coast spa's are a really good make and running coast don't get much better than this.
If you feel this is expensive then I would not get a hot tub  :-\
Hope this is useful info for anyone wanting a Spa and are not sure what the running costs are.
  8)
BullFrogSpasMN
Re: Coast Spa Running costs - What you need to know
« Reply #1 on: May 21, 2017, 04:18:23 pm »
assuming my math is correct power is expensive over in Europe...23-24 cents per kwh converted to US currency I believe?
BoxieBoy
« Reply #2 on: May 21, 2017, 05:25:01 pm »
14.38 pence = 19 US cent at todays Brexit price ;) And yes, the UK energy companies are robbing us blind >:(
« Reply #3 on: May 21, 2017, 05:41:46 pm »
240Vac 50Hz supply.
  8)
A small circulation pump model Hot Springs will do a lot better than this.
