Author Topic: Caldera Tahitian Utopia pump leak  (Read 1807 times)
truth649
« on: May 21, 2017, 12:17:19 pm »
I have a pump leaking on a Tahitian Utopia, built around 2004. I have a feeling it froze over the winter when we had a power outage. Is it safe to say the pump needs to be replaced? I tried to attach a short video of the leak location, but it doesn't seem to be working. Water is pouring out from the far left side of the pump on the end. How difficult is a pump replacement? Thanks for any help!
Re: Caldera Tahitian Utopia pump leak
« Reply #1 on: May 21, 2017, 05:50:52 pm »
I would say it needs a new pump. 13 years is a good run for a pump. Turn off breaker, drain tub, disconnect wiring at pump, disconnect plumbing at pump, unbolt pump and remove. Repeat in reverse.
truth649
« Reply #2 on: May 22, 2017, 08:01:54 am »
Thanks for the help, seems easy enough. I just have to figure out what pump to order and where to get it. I assume the pump is marked with a model number but ill take a better look tonight.
