Author Topic: Baquaspa conversion to chlorine  (Read 3357 times)
bub b
« on: August 10, 2004, 01:21:04 pm »
We have a swimming pool using chlorine and a hot tub[sundance optima 4 year old] using baquaspa.I will like to convert the hot tub to di-chlor using n2,so we can use both at the same time. I know that you have to flush the tub several times but with what chemicals.Any info will be appreciated.Keep on tubbing!!!
Warkovision
  • West and Wewaxsation, at Wast!
Re: Baquaspa conversion to chlorine
« Reply #1 on: August 10, 2004, 05:38:13 pm »
« Reply #2 on: August 10, 2004, 05:50:15 pm »
Drain thoroughly. This may mean drain and partially refill and then drain again. Or just drain, and leave the hose running for awhile with the drain valve open. Whatever works for your tub to get as much of the old water out as you can.
Flush the plumbing lines. This may mean simply putting the garden hose in a couple of jets, or it may mean drain, refilling, running the jets, then draining again. Again, whatever works for your spa to get as much of the old water out as you can.
Wash the filters by soaking in a non-baqua filter cleaner. You most likely needed to do this anyway.
Refill, balance, and shock with Dichlor.
Heat, and add people.
