Author Topic: 110V or 220V?  (Read 9123 times)
Re: 110V or 220V?
« Reply #15 on: August 07, 2004, 10:42:08 pm »
Sounds like you may be a candidate for some buddy breakers. Two breakers in the space of one. Ask an electrician.
« Last Edit: August 07, 2004, 10:53:14 pm by Chas »
Re: 110V or 220V?
Re: 110V or 220V?
« Reply #16 on: August 09, 2004, 09:18:54 am »
Brewman, you are absolutely right!  I was being a curmudgeon and I apologize!  (Just spent 30 minutes in the hottub and the world seems a lot more peaceful - sorry for upsetting the balance!)
No problem!!  There is plenty of room on the curmudgeon couch.  Hop on!   ;D
Re: 110V or 220V?
« Reply #17 on: August 09, 2004, 09:24:37 am »
With 200 amp service, you should have plenty of capacity to add that spa.
Just for general information, load calculations have nothing to do with adding up the total amperage on your breakers.  This is a common mis conception, and it often freaks people out who add up the breakers and come up with a total which is in excess of their capacity.
Good luck with your spa!
doodoo
Re: 110V or 220V?
« Reply #18 on: August 09, 2004, 09:53:04 am »
That was exactly our situation.  I am not beyond ignorant when it comes with electrical work. I can change or add new circuits or run them off existing lines. But when I called our electrician to come and install our GFCI panel outside I certainly felt like one. :P
He took one look at the main panel (200amp) and told me ''no problem you got plenty of capacity here'' :) I said ''but all the slots are taken and by my count I end up at 210amps'' ??? ''I could start a fire if everything was on'':o His response a very long drawn out chuckle that was filled with confidence.  :-[
He proceeded to explain exactly what Brewman and UTS are describing here.  In the end, no major work just simply some reworking of breakers, the installation of the GFCI panel, some wire and a solid lesson learned by yours truly, Don't mess with that doodoo unless you are qualified to mess with.  ;D
ps. the moderator may feel like this is too riské and is more than welcome to edit.
« Last Edit: August 09, 2004, 09:55:41 am by doodoo »
Re: 110V or 220V?
