Author Topic: Calspa problem  (Read 9230 times)
Garretthes
Calspa problem
« on: February 26, 2017, 07:16:21 pm »
Hello! We bought a home recently and were fortunate to inherit a 10 year old Calspa. It's a two pump spa. Recently while we were in the spa and had the pumps running at maximum, one side just quick working. It's the side with the heavy duty jets. The other side works fine. Both motors are working too. Any ideas?
Calspa problem
Re: Calspa problem
« Reply #1 on: February 26, 2017, 09:24:31 pm »
Do you have a diverter valve that changes where the pumps push water?
Garretthes
Re: Calspa problem
« Reply #2 on: February 28, 2017, 01:23:04 pm »
There are several knobs that control the water and air but they don't make any difference. Are you referring to a valve under the service panel? What does it look like?
Re: Calspa problem
« Reply #3 on: February 28, 2017, 04:37:34 pm »
It would be up on the edge of the tub and controllable from in the tub. And should send water to different jets.
Garretthes
Re: Calspa problem
« Reply #4 on: March 01, 2017, 08:03:08 am »
There are several diverters.
Hottubprosne
Re: Calspa problem
« Reply #5 on: March 03, 2017, 11:46:10 am »
So you were using the tub jets running and with out moving or changing anything half the jets quit working?
Garretthes
Re: Calspa problem
« Reply #6 on: March 03, 2017, 01:27:37 pm »
Yes, that's exactly what happened.
Re: Calspa problem
« Reply #7 on: March 03, 2017, 03:22:12 pm »
Failed diverter?
Hottubprosne
Re: Calspa problem
« Reply #8 on: March 03, 2017, 03:35:04 pm »
If the tub has two pumps make sure they are actually running. If they are look in the cabinet for the slicer valves. They are white t handle looking things. Each pump will have two one on each side make sure they are both pulled all the way up. Careful you don't pull too hard and pull the handle all the way out. they should all look about the same. Do this and let me know. Did you say its an 06?
Garretthes
Re: Calspa problem
« Reply #9 on: March 03, 2017, 03:39:22 pm »
It is an 06. I checked the handles the other day, They are all in the out position. The pumps both run.
Hottubprosne
Re: Calspa problem
« Reply #10 on: March 06, 2017, 03:44:45 pm »
So which jets dont work what is the model of tub?
Garretthes
Re: Calspa problem
« Reply #11 on: March 06, 2017, 10:49:54 pm »
It's a Cal spa 734L Avalon 6 person tub. There is a lounge seat on the side with the controls. These jets work. The jets on the same side/different corner as the filters don't work. This is the seat with all the high pressure jets that cover your back. There are similar jets on the opposite corner from the filters. These don't work either. So basically half the tub.
Hottubprosne
Re: Calspa problem
« Reply #12 on: March 07, 2017, 04:13:55 pm »
Are you sure it has two pumps? Or just two speeds? Pump one has low and high speed if it has pump two it is high speed only whats the serial number? How many large divertors are there on the top should be at least one maybe two.
Garretthes
Re: Calspa problem
« Reply #13 on: March 07, 2017, 04:24:44 pm »
I can take a photo of the diverters later this week. I took the access panel off to check that the pumps were working and saw the two pumps.
Garretthes
Re: Calspa problem
« Reply #14 on: September 02, 2017, 07:58:05 pm »
Here is a video of my problem. Hope someone can help!
https://www.youtube.com/watch?v=BEd9yQRyF4A&feature=em-upload_owner
Re: Calspa problem
