Author Topic: CYA range to start bleach method  (Read 3770 times)
Calisoldier83
« on: February 19, 2017, 06:21:07 pm »
What's the CYA range to start the bleach method? I creeped up to around 45 and wondering if I should attempt.
Bigralphy
Re: CYA range to start bleach method
« Reply #1 on: February 19, 2017, 09:37:05 pm »
I usually get the cya to 40 myself before starting bleach.  Make sure your ta is 50 and pH 7.8. I have been using this for 2 years now and always have clear water.
I'm sure others will chime in.
Calisoldier83
« Reply #2 on: February 19, 2017, 10:20:09 pm »
Why TA 50? I'm right at 80.
BullFrogSpasMN
« Reply #3 on: February 20, 2017, 12:22:11 pm »
some need to keep TA slightly lower to maintain pH stability...common recommended TA range is 40ppm - 80ppm
Calisoldier83
« Reply #4 on: February 20, 2017, 08:27:52 pm »
Gotcha. Is there a rule of thumb for bleach after each use? Dichlor was 2tsp pp for a normal soak. I bought the 8.25% from Costco.
« Last Edit: February 21, 2017, 07:40:18 am by wmccall »
bud16415
« Reply #5 on: February 21, 2017, 08:47:36 am »
[/quote]
[/quote]
I experimented by checking before and after adding the bleach and found a small plastic cup that came with the laundry soap was the right amount for mine. I never measured how much it holds but most nights give it one if we had guests and heavy usage I’ll give it two.  Won’t take you long to dial it in.
Calisoldier83
« Reply #6 on: February 21, 2017, 01:56:41 pm »
Okay thanks. I'm seeing a lot of discussion around adding Borates to stabilize pH. Is this necessary? I was trying to avoid having muriatic acid around and it looks like it necessary if you start messing with Borates.
