Author Topic: Wait or not wait  (Read 3360 times)
mikec
Wait or not wait
« on: January 04, 2017, 11:53:30 am »
Are hot tubs fragile and do they damage easily while moving them?
I'm in the Army and have 20 months until I retire.  I want a hot tub and wondering how hard they are to move since I will relocate after retirement.
I do not know where I will retire, so I don't know how far I will need to move it.  What I do know is I want a hot tub, but will wait if there is a risk of damage while moving it.
Thank you in advance for your advice,
Mike
Wait or not wait
The Wizard of Spas
Re: Wait or not wait
« Reply #1 on: January 04, 2017, 12:43:46 pm »
New tubs tend to be very sturdy and can be moved with relative** ease in the first 5 years or so.  After that its all about the makeup of the base and cabinet, and how well said things were taken care of.  Even so- you should still be okay to have the tub moved.
**relative as in the unit is from a reputable major manufacturer, and isn't set in a difficult setting to remove.
Hope this helps.
« Reply #2 on: January 04, 2017, 05:30:50 pm »
Hope this helps.
Also depends on the ability of the movers.
The Wizard of Spas
« Reply #3 on: January 04, 2017, 05:54:07 pm »
Hope this helps.
+1 (Good Catch)
GrayBeardCA
« Reply #4 on: January 06, 2017, 07:21:26 pm »
It depends on if you're doing a DITY move or letting the Army do it  8)
I hear that Dimension - One is Veteran owned.
« Reply #5 on: January 06, 2017, 07:35:41 pm »
Dimension one is not veteran owned. How hard is the delivery?  If it's pretty easy then it should be fairly easy to move
GrayBeardCA
« Reply #6 on: January 06, 2017, 07:48:59 pm »
My local D1 dealer (along with others) has a D1 veteran owned badge on their website. It also appears on buyveteran.com Is this no longer true?
http://www.buyveteran.com/listings/?search_keywords=Dimension+One&search_location=&search_categories%5B%5D=&use_search_radius=on&search_radius=50&search_lat=0&search_lng=0&search_region=&search_context=7
« Reply #7 on: January 06, 2017, 08:43:46 pm »
It may have been a few years back but they were sold to the Apollo Group (jacuzzi, Sundance, thermospas) a few years ago. Before that they were owned by a guy in California. Maybe he was a veteran but I'm not sure about that
« Reply #8 on: January 07, 2017, 09:21:09 am »
The only thing of value I can add to this thread is that in 13 years, I've seen many posts that said, "It was working at the original site and after moving it, I have this problem........"
