Author Topic: Slope on a concrete slab  (Read 4815 times)
Starman
« on: December 29, 2016, 02:12:01 pm »
I have a concrete slab and pool screen about to be built to house a spa.
They were talking about a 2 " slope. The manufacturer said 1 " was okay . BTW the slab  is 25' width x 20" Long.
The manufacturer also said to place the skimmer/filter on the low side which is not really possible.
Is 1 " really going to make much of a difference?? What is the issue?
Re: Slope on a concrete slab
« Reply #1 on: December 30, 2016, 08:56:42 pm »
2" slope is 1" in 10' so an 8' tub has less than an inch of tilt. Your should be fine. Might be a little high on one side and splash out more during your party's. Make sure the suction weir is at the right water level always.
There are ways to level just where the tub sits. Is that not an option?
I would notice it because I'm picky that way. Most won't notice it.
Starman
« Reply #2 on: December 31, 2016, 03:35:42 am »
Thanks for responding, can you explain a bit more about this is possible??
« Reply #3 on: December 31, 2016, 07:39:47 am »
There are products you pour into a form and they harden and level the surface. Rapid set concrete leveler.
If the mix is watery enough it will self level inside the form.
« Last Edit: December 31, 2016, 05:47:20 pm by Tman122 »
Calisoldier83
« Reply #4 on: December 31, 2016, 06:12:57 pm »
Mine is on a slope. The contractor made it work. It's slightly sloped, maybe the 1" and the skimmer is on the receiving end of the slope.
Calisoldier83
« Reply #5 on: December 31, 2016, 06:18:53 pm »
« Last Edit: December 31, 2016, 06:30:19 pm by Calisoldier83 »
