Author Topic: Marquis Spas Mirage, some jets not blowing out water  (Read 7993 times)
MarKee
Re: Marquis Spas Mirage, some jets not blowing out water
« Reply #15 on: December 08, 2016, 10:58:25 pm »
Do you have the serial number on the spa? You likely need the 350-6297 tri-zone/3-way valve.  In 2007 they made the Mirage in the "Limited Series" under the model name 520M.  I believe it used the 3-way valve.
« Reply #16 on: December 08, 2016, 11:02:29 pm »
If you have everything but the insert then just get that. I think that part is the same on the current ones. Should just be just a Tri zone insert
« Reply #17 on: December 08, 2016, 11:08:42 pm »
That part is the insert only isn't it?
Sumpter28
« Reply #18 on: December 08, 2016, 11:34:17 pm »
Ill need to look at the hot tub when i get home for the number, but Markee i believe you're right. Thats how it was labeled on the paperwork.
MarKee
« Reply #19 on: December 09, 2016, 01:38:11 pm »
Hottubguy was right- if it's a 2007 520M Mirage, that spa used a 2-way valve which is part number 350-6283.  The 2-way valve was typically black in color and about 4" long when you unscrew the top ring it and take it out.  A 3-way valve is 8-9" long and white in color.  I would take the valve out and describe to us how it looks.
Sumpter28
« Reply #20 on: December 09, 2016, 02:34:35 pm »
Okay, soon as my family and I get home after festivites I will check the valve.
Sumpter28
« Reply #21 on: December 14, 2016, 02:59:23 am »
Okay home now, was working on the hot tub trying to take the insert out, but its being a pain to take out. As far as i could tell it should just pop right out correct? Any tips or tricks you guys can tell me?
« Reply #22 on: December 14, 2016, 06:57:30 pm »
Long needle nose pliers?
MarKee
« Reply #23 on: December 16, 2016, 01:56:36 pm »
If you've taken off the ring that holds the valve in place, it should pop out.  If it's stuck, needle nose pliers or pliers of some sort usually work pretty well like Tman said.
Sumpter28
« Reply #24 on: December 17, 2016, 04:43:05 pm »
Have tried pliers, still cant get it to budge. Any other suggestions?
