Author Topic: Jacuzzi delivery on Friday. Chemicals for newbies?  (Read 16487 times)
Re: Jacuzzi delivery on Friday. Chemicals for newbies?
« Reply #30 on: December 12, 2016, 07:17:36 pm »
Mine gets the same white ring around the water line.  My chemicals are perfectly in line and I recently did a full purge and drain.  I bought some of those sponge things that are supposed to collect body oils and stuff.  They look and feel like those mr eraser cleaner sponges sold for household use.  I let it float around and every day or two I use it to wipe around the edges of my tub where the white film starts to build up.
I have no idea what the stuff is but, left alone, it will get thick and sticky and hard to clean.  When I did my purge, I used Ahhsome and used some baking soda and a rag to clean the edges.  The Ahhsome didn't get all nasty like I've seen in the videos so either I had little biofilm in my new tub or I needed to run it through again.  Regardless, it did not fix my issue with the white film.
My spa guy told me to use less calcium next time I fill my tub.  It is around 250ppm.  I get zero foam in my tub but maybe too much calcium is collecting the body oils and stuff and it is settling against the water lines.
No clue...but that sponge things does clean the white film very easily.
Mpkelley I doubt your tub had much time to get much biofilm. It was less then a month build time to when it was filled at your house plus I filled it at my store for you to try and we used a jet line cleaner when we drained it. There probably was very little to anything in those plumbing libes
mpkelley20
« Reply #31 on: December 13, 2016, 08:59:49 am »
Yeah...I didn't think it would be the issue but since I was doing my first drain and refill, I figured I'd try the ahhsome and see what happens.
Wiping down the sides when I add chlorine each day seems to be fine.  If I don't do it, I do start to see build up right at the water line.  I even noticed it within 3 days after I refilled my tub so I doubt it is an excess of body oils and stuff after that short amount of time.
Calisoldier83
« Reply #32 on: December 13, 2016, 11:06:08 pm »
I'm pretty much over trying to get the PH down. The procedure it calls for is to add 1 1/2 teaspoons and run the jets for 30 mins and test to see if the levels are down. I did this repeatedly for about 5 times and kept getting the same PH reading (8.0). It didn't really budge so I'm assuming that the aeration is counteracting the sodium bisulfate each time.
With the taylor kit, as soon as I added one drop of the acid reagent I was in the 7.3 range, each time.
It looks like that's where it will stay for now. I probably should start with a fresh batch of water and go from there.
« Reply #33 on: December 14, 2016, 01:34:31 am »
 Your water what less than 3 or 4 weeks old if that, it's fine..
  Remember when I told you not to stress over chemicals like a page or 2 ago?  Well your stressing over chemicals!  Put the test kit down, add your sanitizer and shock, enjoy your spa all in that order.  Well maybe add a glass of wine or beer prior to that order, but relax a bit.    Check it once a week if that and enjoy, when the PH drops add PH increaser.
The Wizard of Spas
« Reply #34 on: December 14, 2016, 11:58:57 am »
pH lowering trick:
Add whatever you are using to lower the pH (Muriatic Acid, Sodium Bisulfate) and DO NOT RUN THE JETS.  Let the water stay calm.  This will encourage the reducing agent to work more effectively.  I do this all the time in our in ground pools and hot tubs here in the store.  In fact, I know that it takes 4oz of sodium bisulfate to lower the pH from the tap when I am filling a new tub on the showroom floor.  Thus- I toss the 4oz of dry powder into the footwell and by the time the tub is filled the pH is pretty spot-on.
Try this and I bet you'll be fine.  The only way it doesn't work is if you're testing your pH at, say, 8.6 and that is the highest your pH reader can read but in actuality your pH is, say, 11.  That is why you're adding so much reducer.
Calisoldier83
« Reply #35 on: December 14, 2016, 12:10:42 pm »
pH lowering trick:
I see what you're saying, this is brilliant. My concern is adding sodium bisulfate without running the jets. Couldn't possibly cause damage if not properly circulated in my case on a already filled tub?
The comment about the testing doesn't resonate with me because I'm using the Taylor kit and it gives you the exact amount of chemical you're supposed to use based off reagent.
Beck0101
« Reply #36 on: December 14, 2016, 12:11:55 pm »
For what it's worth it took nearly a full pound of pH Down to get my total alkalinity/pH in order with my first fill.  I, however, have well water.  I guess I wouldn't expect this much to be required on city water.
Adding a few tablespoons at a time can be an exercise in futility if you're "off the charts" high/low.  As soon as I started dumping my chemicals with substantial malice I started getting real movement in my levels.
The Wizard of Spas
« Reply #37 on: December 14, 2016, 02:41:55 pm »
Bisulfate will not cause damage to your jets, etc.  But if you are that concerned, dilute in a buck of water and pour in, leaving jets off.
But I promise that adding it will not damage anything.  As Beck0101 noted- Sometimes you just have to slap it in the face.  Keep track of what you end up adding in total and next time you fill your tub toss about that entire amount into the footwell.  By the time the tub is filled, kicks on and runs a cycle you'll be where you need to be with your pH.
Calisoldier83
« Reply #38 on: December 14, 2016, 04:16:55 pm »
Sounds good. Just curious what you during the post-fill process. It sounds like you've been doing this awhile.
The Wizard of Spas
« Reply #39 on: December 14, 2016, 04:37:49 pm »
I'm just a fan of "less is more:"  Keep pH in line, alkalinity in line, and your sanitizer level in the desired range and you'll be golden.  Thats all I tell my customers to worry about.  I sell a lot of ancillary chemicals products and write hot tub and swimming pool blogs 2x/month but its only for education.  I always preach to keep the big 3 in line and worry about other things only if they arise.
But that is just my perspective.  There are a lot of really smart people on this forum who have other perspectives.  So you can tap into them too by checking other threads about water chemistry.
I just liken water chemistry to a marathon:  The goal is to get to the finish.  But we all can run the race differently.
