When you pay the amount they charge for the tub, you'd assume the above would not be an issue. Thankfully the main meat of the tub is fine.
Here are all the dealers in Florida, I don't know Florida so you decide which is closest. http://www.bullfrogspas.com/stores/florida/
I am a bit bias based on my personal experience, I'd seriously resist buying another Jacuzzi brand if I were to shop again.Same story as Jacuzzi Jim and others for my dealer. Jacuzzi dumped them (and the other dealer in the area) and moved to some new Canadian place that expanded to South Florida. Now they cannot get parts for me and I was told to call Jacuzzi to see if the other place will cover me. Before then, same thing of slow to get parts, etc. So, even though it has a warranty, I wonder how much of a hassle it will be if something major goes wrong, or how much the service call will be.As for my tub itself, quality control was just not there. Maybe my tub was made on Cinco de Mayo or something.I had:- Some of the connectors inside were not fully inserted from factory. Odd they do not use other style connectors that would click and hold.- ALL 4 cupholder leds died within 6 months of ownership. Looking closely, it seems like they were over-tightened and had a hairline crack in them, over time, died. Just to jinx it, they have been fine since replacing.- BOTH waterfall leds are non-functioning. These too died within 6 months. Replaced. Replacements died within the next year. Looks like the build of them are not 100% waterproof. You can see the rust inside and where water got in. VERY poor design and/or craftsmanship. - leds only have 1 year warranty. So, unless I want to pay over $200 for the parts alone, I have no more leds for my waterfall at all. Even if I pay $200, they will be the same as what we have now, and will go bad in no time, so gave up on the waterfall lights.- One of my jets did not work right from the start. Ended up being a kinked hose from the factory. There was water in the system when we received the tub, so you know they "tested" it, but the jet was non-existent until the hose was rerouted to prevent the kink.- Now, my main filter intake "whistles" if I tighten the filter too much. If I leave it the slightest bit loose, no whistle, only for a second when circulation pump starts. I think that joint has a hairline crack in it.- My lifter was had the foam handles already torn within 2 weeks, replacements were sent, but since things are welded between, not sure how they can be installed.- In replacing the cupholders, the lilfter gouged the siding, so had to replace that too.- one jet just does not seem to push as much volume as it's twin in the seat, that could be imagination or me being too critical based on the above. It's not worth the effort to see why, it is still good enough.- The headrest pillows snap into place, they stay on fine, but if you want to remove them to clean you can see where they might not stay for long, but so far so good.Don't get me wrong, it is a nice tub that has no lights for the waterfall. I still enjoy it and try and forget the above. When you pay the amount they charge for the tub, you'd assume the above would not be an issue. Thankfully the main meat of the tub is fine. We use it just about every night and have had it almost two and a half years. Oh, and the foot dome is still my favorite part. Not only does it help your feet, it keeps me in place instead of floating away. The experience has made it where I don't think our next house will have our own tub, or ever buy another. I think they may be similar to a boat. It's better to know someone with a boat than to be the guy with the boat.You can look at my profile and show the posts/topics I wrote to find more details on the above.
Have you had issues with the jacuzzi needing a reset? I just got mine two nights ago and last night the lights simply would not turn on. I needed to reset the tub at the breaker. Was kinda annoyed, but happy it wasn't broken.
Like mentioned, Bullfrog is taking floor space from Jacuzzi and Sundance dealers, and pretty sure some HS dealers here and there. Many of the reps for Bullfrog are from Jacuzzi though not sure how many. It pretty much pissed Jacuzzi off, specially losing floor space. I do think it's the protocol to not support ex dealers with parts and support, but I can tell you most if not all our Jacuzzi customers will not buy another Jacuzzi because of it.
I've seemed the encounter a problem (hopefully not the plague), where I can't turn off the fountain, even after restarting the spa. There seems to be an issue already, geez.
Well, the dealer who Jacuzzi replaced everyone in the area with were good. Quick replies, polite, etc. In the end, I am still stuck with a tub with a hole in it until I buy the replacement part. Since the plastic part that holds the headrest on has a light in it, Jacuzzi says it is out of warranty. A little over two years for that much cash and this many issues. Never again (I hope).Quote from: Calisoldier83 on December 07, 2016, 01:02:04 pmI've seemed the encounter a problem (hopefully not the plague), where I can't turn off the fountain, even after restarting the spa. There seems to be an issue already, geez.Not turning off, you mean the flow of water or the lights? Not being able to turn off the lights would be something different, because the lights are still getting power. I'd think that is in the control box or one of those blue light controllers (see my other posts). Is it both or only one, since each are on separate controllers.
