Author Topic: Bullfrog spa install question how to seal openings  (Read 3656 times)
Smack528i
« on: October 11, 2016, 07:50:45 pm »
Is there a special way or preferred way to seal the hole drilled at the base of the spa wher the conduit goes in and do you need to seal the 3 openings at the entrance to to equipment compartment? Spa being delivered tomorrow A7.
« Last Edit: October 11, 2016, 07:52:31 pm by Smack528i »
39lasalle
Re: Bullfrog spa install question how to seal openings
« Reply #1 on: October 11, 2016, 09:43:35 pm »
I am planning on using some black RTV
39
tmaestas95
« Reply #2 on: October 11, 2016, 10:55:30 pm »
There was a small black "cap" included in my install packet that looks like it is meant to go into whichever hole you drill out for the conduit entrance that would provide a tight fit for standard 3/4" liquidtight flex....however I didn't notice it until after my electrician had already run the conduit in so I haven't used it.  I suppose i could snip one end to fit it over the conduit.  Or you could just use a bit of expanding foam or silicone.  I wouldn't bother sealing the other 2 unused entrances inside the equipment compartment as there's really no access to them from outside assuming your tub is on a continuous flat surface.
Smack528i
« Reply #3 on: October 12, 2016, 08:13:25 am »
Ok. I'll look for it or just use the sealant as planned. Thanks.
Smack528i
« Reply #4 on: October 12, 2016, 08:32:11 pm »
mvandenberk
« Reply #5 on: October 14, 2016, 09:49:52 am »
I just filled mine with silicone.
