Author Topic: tub will not run  (Read 1826 times)
Riley012
tub will not run
« on: October 11, 2016, 02:58:22 pm »
I have a shoreline hot tub, about 6 years old. I have power to the unit but it will not run. I checked the fuses and they all seem fine. any help would be appreciated. T?hanks
tub will not run
Re: tub will not run
« Reply #1 on: October 11, 2016, 03:43:37 pm »
Do you have an electrical tester? See that the tub for sure has power and check continuity on the fuses.
Riley012
« Reply #2 on: October 12, 2016, 11:35:58 am »
I checked the fuses with a tester and they seem fine, someone told me to check to make sure that it is getting 240 volts. can you explain to me how to do that. Thanks
« Reply #3 on: October 12, 2016, 04:25:45 pm »
You will have either 3 or 4 wires supplying the control box on the tub. The bare copper wire will be ground. The other 3 should be (I say should be because I have seen some weird things over the years) black, red and maybe white. Black should show 105-125 volts to ground and red should show 105-125 volts to ground. White is common and is required to run any 110V compononts in your tub. It may or may not have this. Turn power off and check incoming to the GFCI breaker first. Then power back up and check incoming to the tub.
