Author Topic: HotSpring Grandee - noise from SmartJet lever  (Read 2790 times)
Mikester
« on: October 01, 2016, 11:20:08 am »
When I have my right SmartJet Lever set so the Precision Jet next to it is at full force, it's loud.  Sounds like it's sucking in air.  Very annoying.  When I adjust it down, the noise drops too (though not all the way).
Before, I get the dealer out, any suggestions?  I like having the Precision Jet at full force, but hate having that sucking noise.
Thanks.
BullFrogSpasMN
Re: HotSpring Grandee - noise from SmartJet lever
« Reply #1 on: October 01, 2016, 02:20:22 pm »
quite common, you really have to have those diverters in the perfect spot or they leak air which as noted makes a very annoying sound..a tech may replace the gasket and/or they also make a complete diverter repair/rebuild kit that I believe sells for under $75 that will replace all of the "guts" of the diverter hopefully sealing up the air leak....good luck!
Mikester
« Reply #2 on: October 01, 2016, 08:48:14 pm »
Thanks.  Should it be a warranty issue?  The tub's 6 months old.
If I replace, pretty straight forward?  Wondering if I can pop it off, maybe try re-seating the gasket.
