Author Topic: How to drain a J235 Jacuzzi Hot Tub - New Owner  (Read 6431 times)
delt31
« on: September 06, 2016, 07:27:11 am »
Can't figure out how to properly drain the hot tub (J235 Jacuzzi). I see a gravity drain INSIDE the tub itself but can't figure out how to use it. I believe you can use the fast drain within the unit itself but which panels do I need to remove to get inside?  I know which side of the tub but there are many panels and not sure what to unscrew.  Any suggestions?
mjb
Re: How to drain a J235 Jacuzzi Hot Tub - New Owner
« Reply #1 on: September 06, 2016, 11:07:13 am »
Take the front right corner boards off and you should see the plastic drain line to your left.
It may be zip tied to a vertical support.  Un-do it and screw your garden hose on and let it drain to the yard.  DON'T forget to turn off the power to the spa at your breaker or disconnect.
