Author Topic: Hot tub base  (Read 3208 times)
39lasalle
Hot tub base
« on: August 20, 2016, 10:07:02 pm »
So it looks like we are going to go with the Flair.  I have a stone pad that I originally wanted to put the tub on and I do not want to do a cement pad for future concerns. It looks like Hot Springs either recommends cement, pavers or a deck.   I think I want to build a deck out of 2X6 frame and top it off with 2x4's, all pressure treated.  I will place this on my stone pad.
Does anyone see any concerns with this plan?
39
Hot tub base
jmk1234
Re: Hot tub base
« Reply #1 on: August 21, 2016, 03:45:44 am »
If the deck is going to be built around the tub, make sure you can get to the tub to do maintenance if needed. I had to remove my deck because the previous seller decided to build around the tub and I couldn't access none of the equipment. Just save some heartache there.
39lasalle
Re: Hot tub base
« Reply #2 on: August 21, 2016, 09:21:29 am »
No, I just want to build a 8' x 8' square deck for the tub to sit on.
39
Re: Hot tub base
« Reply #3 on: August 21, 2016, 12:42:48 pm »
39
As long as you build it properly to support the weight of the spa/water/people that'll be fine.
Re: Hot tub base
