Author Topic: Bullfrog A series Auxilliary Control Pad loose on top  (Read 3626 times)
tomas21
« on: July 17, 2016, 01:02:02 am »
Does anyone know how to tight down the bullfrog Auxilliary Control Pad that is on the top of the A series?  I have one that is lifting up around the trim to the control pad.
Re: Bullfrog A series Auxilliary Control Pad loose on top
« Reply #1 on: July 17, 2016, 10:50:22 am »
 I think it's just a sticker but not sure?
tomas21
« Reply #2 on: July 17, 2016, 11:29:41 am »
The black plastic trim ring around the aux control pad that sits flush on the spa shell is not flush on the shell like the other side and my previous bullfrog a8.
Im not sure how these are installed at the factory and if there is a way to tighten down the trim ring to keep water from going down it and looking nicer.
« Last Edit: July 17, 2016, 11:43:08 am by tomas21 »
Hottubprosne
« Reply #3 on: July 18, 2016, 12:06:21 pm »
Like jacuzzi jim said its just two sided tape pry it up clean it and the surface light bead of silicon.  It should be covered by your dealer.
dmcmillen
« Reply #4 on: July 21, 2016, 06:28:35 am »
I have this problem on my A7. I'm getting in touch with the dealer and will report back.
tomas21
« Reply #5 on: July 22, 2016, 05:49:02 pm »
I contacted BF directly and they stated 2 options
- The trim piece is just held by doublesided tape (pull up, clean it, and put a dab of silicon on the shell, and push back down)
- Contact your dealer and request a replacement Control pad (remove old one, route cable to control panel, clean shell surface, and install new one)
Let me know what your dealer ends up doing for you.
